Rohde & Schwarz MDS-21
The Rohde & Schwarz MDS-21 device driver is a Antenna, LISN, Absorbing Clamp which is supported by RadiMation®.
The frequency range of the Rohde & Schwarz MDS-21 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Rohde & Schwarz MDS-21.
Be careful changing these settings as RadiMation® is no longer able to verify if the Rohde & Schwarz MDS-21 is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Rohde & Schwarz MDS-21
- Google image search: Rohde & Schwarz MDS-21
