Rohde & Schwarz SMB 100B
The Rohde & Schwarz SMB 100B device driver is a Signal Generator which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Rohde & Schwarz SMB 100B:
The frequency range of the Rohde & Schwarz SMB 100B as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Rohde & Schwarz SMB 100B.
Be careful changing these settings as RadiMation® is no longer able to verify if the Rohde & Schwarz SMB 100B is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Rohde & Schwarz SMB 100B
- Google image search: Rohde & Schwarz SMB 100B
