Rohde & Schwarz SMG (With AFG Modulator) (ELASIS)
The Rohde & Schwarz SMG (With AFG Modulator) (ELASIS) device driver is a Signal Generator which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Rohde & Schwarz SMG (With AFG Modulator) (ELASIS):
The frequency range of the Rohde & Schwarz SMG (With AFG Modulator) (ELASIS) as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Rohde & Schwarz SMG (With AFG Modulator) (ELASIS).
Be careful changing these settings as RadiMation® is no longer able to verify if the Rohde & Schwarz SMG (With AFG Modulator) (ELASIS) is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Rohde & Schwarz SMG (With AFG Modulator) (ELASIS)
- Google image search: Rohde & Schwarz SMG (With AFG Modulator) (ELASIS)
