Rohde & Schwarz SMIQ 03B
The Rohde & Schwarz SMIQ 03B device driver is a Signal Generator which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Rohde & Schwarz SMIQ 03B:
The frequency range of the Rohde & Schwarz SMIQ 03B as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Rohde & Schwarz SMIQ 03B.
Be careful changing these settings as RadiMation® is no longer able to verify if the Rohde & Schwarz SMIQ 03B is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Rohde & Schwarz SMIQ 03B
- Google image search: Rohde & Schwarz SMIQ 03B
