Rohde & Schwarz SMIQ 04B (GSM Modulation)
The Rohde & Schwarz SMIQ 04B (GSM Modulation) device driver is a Signal Generator which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Rohde & Schwarz SMIQ 04B (GSM Modulation):
The frequency range of the Rohde & Schwarz SMIQ 04B (GSM Modulation) as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Rohde & Schwarz SMIQ 04B (GSM Modulation).
Be careful changing these settings as RadiMation® is no longer able to verify if the Rohde & Schwarz SMIQ 04B (GSM Modulation) is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Rohde & Schwarz SMIQ 04B (GSM Modulation)
- Google image search: Rohde & Schwarz SMIQ 04B (GSM Modulation)
