Rohde & Schwarz SMIQ 06ATE
The Rohde & Schwarz SMIQ 06ATE device driver is a Signal Generator which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Rohde & Schwarz SMIQ 06ATE:
The frequency range of the Rohde & Schwarz SMIQ 06ATE as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Rohde & Schwarz SMIQ 06ATE.
Be careful changing these settings as RadiMation® is no longer able to verify if the Rohde & Schwarz SMIQ 06ATE is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Rohde & Schwarz SMIQ 06ATE
- Google image search: Rohde & Schwarz SMIQ 06ATE
