Rohde & Schwarz SMR 20
The Rohde & Schwarz SMR 20 device driver is a Signal Generator which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Rohde & Schwarz SMR 20:
The frequency range of the Rohde & Schwarz SMR 20 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Rohde & Schwarz SMR 20.
Be careful changing these settings as RadiMation® is no longer able to verify if the Rohde & Schwarz SMR 20 is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
