Rohde & Schwarz SMR 27 (Ext PM)
The Rohde & Schwarz SMR 27 (Ext PM) device driver is a Signal Generator which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Rohde & Schwarz SMR 27 (Ext PM):
The frequency range of the Rohde & Schwarz SMR 27 (Ext PM) as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Rohde & Schwarz SMR 27 (Ext PM).
Be careful changing these settings as RadiMation® is no longer able to verify if the Rohde & Schwarz SMR 27 (Ext PM) is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Rohde & Schwarz SMR 27 (Ext PM)
- Google image search: Rohde & Schwarz SMR 27 (Ext PM)
