Rohde & Schwarz SMT 03 (Drager)
The Rohde & Schwarz SMT 03 (Drager) device driver is a Signal Generator which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Rohde & Schwarz SMT 03 (Drager):
The frequency range of the Rohde & Schwarz SMT 03 (Drager) as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Rohde & Schwarz SMT 03 (Drager).
Be careful changing these settings as RadiMation® is no longer able to verify if the Rohde & Schwarz SMT 03 (Drager) is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Rohde & Schwarz SMT 03 (Drager)
- Google image search: Rohde & Schwarz SMT 03 (Drager)
