Rohde & Schwarz SMY-01
The Rohde & Schwarz SMY-01 device driver is a Signal Generator which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Rohde & Schwarz SMY-01:
The frequency range of the Rohde & Schwarz SMY-01 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Rohde & Schwarz SMY-01.
Be careful changing these settings as RadiMation® is no longer able to verify if the Rohde & Schwarz SMY-01 is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
Documentation
The user manual of the SMY can be found here
