Rohde & Schwarz SMY-02 (PM Ext Blanking)
The Rohde & Schwarz SMY-02 (PM Ext Blanking) device driver is a Signal Generator which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Rohde & Schwarz SMY-02 (PM Ext Blanking):
The frequency range of the Rohde & Schwarz SMY-02 (PM Ext Blanking) as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Rohde & Schwarz SMY-02 (PM Ext Blanking).
Be careful changing these settings as RadiMation® is no longer able to verify if the Rohde & Schwarz SMY-02 (PM Ext Blanking) is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
Documentation
The user manual of the SMY can be found here
