Rohde & Schwarz UP300 (FREQ DC RMS)
The Rohde & Schwarz UP300 (FREQ DC RMS) device driver is a AD Converter which is supported by RadiMation®.
- Google search: Rohde & Schwarz UP300 (FREQ DC RMS)
- Google image search: Rohde & Schwarz UP300 (FREQ DC RMS)
To use this device in RadiMation® you need to install some device drivers. Please click on the following link to download the installation program: Media: Rssiup_vxipnp_1_6.zip. Extract the zip file and start the installation. This installer can also be downloaded from the website of the manufacturer: [1]. Select VXIplug&play driver for R&S®UP300/UP350 Audio Analyzers. With this software it should also be possible to retrieve the correct USB identifier of the equipment.
The above installation program does not install an USB device driver for the UP 300. To use the device by USB and in RadiMation® you need to download the following drivers: Media: Rssi_usb_driver.zip. Unzip it and use the Microsoft Windows Device Manager to install the device driver. It is absolutely required that these device drivers are properly installed. Otherwise it is not possible that the equipment is being remote controlled by other software. Unfortunately, Rohde and Schwarz only supports the 32 bit version of the USB drivers for this equipment.
Minimum required driver version: >=1.6, 03/2008
