Rohde & Schwarz ZVB 20
The Rohde & Schwarz ZVB 20 device driver is a Network Analyser which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Rohde & Schwarz ZVB 20:
The frequency range of the Rohde & Schwarz ZVB 20 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Rohde & Schwarz ZVB 20.
Be careful changing these setting as RadiMation® is no longer able to verify if the Rohde & Schwarz ZVB 20 is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: Rohde & Schwarz ZVB 20
- Google image search: Rohde & Schwarz ZVB 20
