Rohde & Schwarz ZVK
The Rohde & Schwarz ZVK device driver is a Signal Generator, Spectrum Analyser, Network Analyser which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Rohde & Schwarz ZVK:
The frequency range of the Rohde & Schwarz ZVK as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Rohde & Schwarz ZVK.
Be careful changing these settings as RadiMation® is no longer able to verify if the Rohde & Schwarz ZVK is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Rohde & Schwarz ZVK
- Google image search: Rohde & Schwarz ZVK
