Rolf Heine HA-17
The Rolf Heine HA-17 device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Rolf Heine HA-17:
The frequency range of the Rolf Heine HA-17 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Rolf Heine HA-17.
Be careful changing these settings as RadiMation® is no longer able to verify if the Rolf Heine HA-17 is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Rolf Heine HA-17
- Google image search: Rolf Heine HA-17
