Rolf Heine HL-1000
The Rolf Heine HL-1000 device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Rolf Heine HL-1000:
The frequency range of the Rolf Heine HL-1000 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Rolf Heine HL-1000.
Be careful changing these settings as RadiMation® is no longer able to verify if the Rolf Heine HL-1000 is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Rolf Heine HL-1000
- Google image search: Rolf Heine HL-1000
