SPIN SPIN 3W
The SPIN SPIN 3W device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the SPIN SPIN 3W:
The frequency range of the SPIN SPIN 3W as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the SPIN SPIN 3W.
Be careful changing these settings as RadiMation® is no longer able to verify if the SPIN SPIN 3W is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: SPIN SPIN 3W
- Google image search: SPIN SPIN 3W
