SPIN SPIN 5W
The SPIN SPIN 5W device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the SPIN SPIN 5W:
The frequency range of the SPIN SPIN 5W as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the SPIN SPIN 5W.
Be careful changing these settings as RadiMation® is no longer able to verify if the SPIN SPIN 5W is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
