SUNAR JB3
The SUNAR JB3 device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the SUNAR JB3:
The frequency range of the SUNAR JB3 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the SUNAR JB3.
Be careful changing these settings as RadiMation® is no longer able to verify if the SUNAR JB3 is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
