Schaffner Broadband Horn
The Schaffner Broadband Horn device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Schaffner Broadband Horn:
The frequency range of the Schaffner Broadband Horn as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Schaffner Broadband Horn.
Be careful changing these settings as RadiMation® is no longer able to verify if the Schaffner Broadband Horn is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Schaffner Broadband Horn
- Google image search: Schaffner Broadband Horn
