Schaffner CBL 6140A
The Schaffner CBL 6140A device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Schaffner CBL 6140A:
The frequency range of the Schaffner CBL 6140A as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Schaffner CBL 6140A.
Be careful changing these settings as RadiMation® is no longer able to verify if the Schaffner CBL 6140A is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Schaffner CBL 6140A
- Google image search: Schaffner CBL 6140A
