Schaffner CBL 6143
The Schaffner CBL 6143 device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Schaffner CBL 6143:
The frequency range of the Schaffner CBL 6143 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Schaffner CBL 6143.
Be careful changing these settings as RadiMation® is no longer able to verify if the Schaffner CBL 6143 is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Schaffner CBL 6143
- Google image search: Schaffner CBL 6143
