Schaffner DPA 3000
The Schaffner DPA 3000 device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Schaffner DPA 3000:
The frequency range of the Schaffner DPA 3000 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Schaffner DPA 3000.
Be careful changing these settings as RadiMation® is no longer able to verify if the Schaffner DPA 3000 is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Schaffner DPA 3000
- Google image search: Schaffner DPA 3000
