Schlöder CDG6000 Amplifier
The Schlöder CDG6000 Amplifier device driver is a Amplifier which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Schlöder CDG6000 Amplifier:
The frequency range of the Schlöder CDG6000 Amplifier as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Schlöder CDG6000 Amplifier.
Be careful changing these settings as RadiMation® is no longer able to verify if the Schlöder CDG6000 Amplifier is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Schlöder CDG6000 Amplifier
- Google image search: Schlöder CDG6000 Amplifier
