Schlöder CDG6000 Coupler
The Schlöder CDG6000 Coupler device driver is a Coupler which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Schlöder CDG6000 Coupler:
The frequency range of the Schlöder CDG6000 Coupler as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Schlöder CDG6000 Coupler.
Be careful changing these settings as RadiMation® is no longer able to verify if the Schlöder CDG6000 Coupler is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Schlöder CDG6000 Coupler
- Google image search: Schlöder CDG6000 Coupler
