Schlöder CDN M2-32 HV
The Schlöder CDN M2-32 HV device driver is a LISN which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Schlöder CDN M2-32 HV:
The frequency range of the Schlöder CDN M2-32 HV as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Schlöder CDN M2-32 HV.
Be careful changing these settings as RadiMation® is no longer able to verify if the Schlöder CDN M2-32 HV is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Schlöder CDN M2-32 HV
- Google image search: Schlöder CDN M2-32 HV
