Schlöder CDG6000 Signal Generator
Jump to: navigation, search
The Schlöder CDG6000 Signal Generator device driver is a Signal Generator which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Schlöder CDG6000 Signal Generator:
The frequency range of the Schlöder CDG6000 Signal Generator as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Schlöder CDG6000 Signal Generator.
Be careful changing these setting as RadiMation® is no longer able to verify if the Schlöder CDG6000 Signal Generator is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
