Schlöder CDN M2-100 HV
The Schlöder CDN M2-100 HV device driver is a LISN which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Schlöder CDN M2-100 HV:
The frequency range of the Schlöder CDN M2-100 HV as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Schlöder CDN M2-100 HV.
Be careful changing these setting as RadiMation® is no longer able to verify if the Schlöder CDN M2-100 HV is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: Schlöder CDN M2-100 HV
- Google image search: Schlöder CDN M2-100 HV
