Schlöder EMCL-20
The Schlöder EMCL-20 device driver is a Injection DeviceCalibration Jig which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Schlöder EMCL-20:
The frequency range of the Schlöder EMCL-20 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Schlöder EMCL-20.
Be careful changing these setting as RadiMation® is no longer able to verify if the Schlöder EMCL-20 is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
