The Schneider Electric Modbus device driver is a AD Converter which is supported by RadiMation®.
The Schneider Electric Modbus device driver can be configured to read specific registers from a Modbus module, and present the values from those registers as EUT monitoring inputs in RadiMation®.
The following tabs are available in this device driver:
Communication Streams
Expected response
The expected *IDN? response of a device. It can be changed in the case the commands are the same for another device for which no RadiMation® driver is available yet.
Restore default
Restores the original Exepected response.
On the Modbus tab, the selection of the modbus module, and the communication protocol to access it can be selected. The following settings are available:
Modbus address
The module address of the Modbus module from which the registers should be read. This address should be between 1 and 247.
Modbus type
Selects the communication type to communicate with the modbus module. Specific addressing like the COM-port or the TCP/IP-address must still be configured on the Communication tab.
ASCII
Uses the text based communication over RS232 / RS485.
RTU
Uses the binary communication protocol over RS232 / RS485.
TCP
Uses ethernet communication based on TCP/IP.
On the Settings tab, the configuration of the registers that should be read, can be configured. Depending on the specific Modbus module being communicated with, these settings should be configured to be matching with the registers available in that Modbus module. The following settings are available:
AD-Channel
The corresponding AD-Channel in RadiMation® for which the configuration is set. Up to 40 channels (matching with 40 possible Modbus registers) can be configured.
Function
The type of read function that is performed on the Modbus module.
Read Holding Register
The value of the holding register is read.
Read Input Register
The value of the input register is read.
Register
The number of the register that should be retrieved and read.
Interpretation
The type of the data as it is read from the register, and how it should be represented in RadiMation®.
Signed Int (16 bit)
The value is represented as a value between -32768 and 32767.
Signed Int (32 bit)
The value is represented as a value between -2147483648 and 2147483647.
Unsigned Int (16 bit)
The value is represented as a value between 0 and 65535.
Unsigned Int (21 bit)
The value is represented as a value between 0 and 4294967295.
Single Precision Floating Point (32 bit)
The value is represented as a 32 bit floating point number.
