Schwarzbeck 419 NJ
The Schwarzbeck 419 NJ device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Schwarzbeck 419 NJ:
The frequency range of the Schwarzbeck 419 NJ as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Schwarzbeck 419 NJ.
Be careful changing these settings as RadiMation® is no longer able to verify if the Schwarzbeck 419 NJ is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Schwarzbeck 419 NJ
- Google image search: Schwarzbeck 419 NJ
