Schwarzbeck BAOC 9216
The Schwarzbeck BAOC 9216 device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Schwarzbeck BAOC 9216:
The frequency range of the Schwarzbeck BAOC 9216 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Schwarzbeck BAOC 9216.
Be careful changing these settings as RadiMation® is no longer able to verify if the Schwarzbeck BAOC 9216 is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Schwarzbeck BAOC 9216
- Google image search: Schwarzbeck BAOC 9216
