Schwarzbeck BBHA 9120D
The Schwarzbeck BBHA 9120D device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Schwarzbeck BBHA 9120D:
The frequency range of the Schwarzbeck BBHA 9120D as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Schwarzbeck BBHA 9120D.
Be careful changing these settings as RadiMation® is no longer able to verify if the Schwarzbeck BBHA 9120D is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Schwarzbeck BBHA 9120D
- Google image search: Schwarzbeck BBHA 9120D
