Schwarzbeck BBHA 9120E
The Schwarzbeck BBHA 9120E device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Schwarzbeck BBHA 9120E:
The frequency range of the Schwarzbeck BBHA 9120E as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Schwarzbeck BBHA 9120E.
Be careful changing these settings as RadiMation® is no longer able to verify if the Schwarzbeck BBHA 9120E is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Schwarzbeck BBHA 9120E
- Google image search: Schwarzbeck BBHA 9120E
