Schwarzbeck BBHA 9120LF
The Schwarzbeck BBHA 9120LF device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Schwarzbeck BBHA 9120LF:
The frequency range of the Schwarzbeck BBHA 9120LF as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Schwarzbeck BBHA 9120LF.
Be careful changing these settings as RadiMation® is no longer able to verify if the Schwarzbeck BBHA 9120LF is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Schwarzbeck BBHA 9120LF
- Google image search: Schwarzbeck BBHA 9120LF
