Schwarzbeck BBHA 9170
The Schwarzbeck BBHA 9170 device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Schwarzbeck BBHA 9170:
The frequency range of the Schwarzbeck BBHA 9170 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Schwarzbeck BBHA 9170.
Be careful changing these settings as RadiMation® is no longer able to verify if the Schwarzbeck BBHA 9170 is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Schwarzbeck BBHA 9170
- Google image search: Schwarzbeck BBHA 9170
