Schwarzbeck CDN AF3
The Schwarzbeck CDN AF3 device driver is a Injection Device, LISN which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Schwarzbeck CDN AF3:
The frequency range of the Schwarzbeck CDN AF3 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Schwarzbeck CDN AF3.
Be careful changing these settings as RadiMation® is no longer able to verify if the Schwarzbeck CDN AF3 is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Schwarzbeck CDN AF3
- Google image search: Schwarzbeck CDN AF3
