Schwarzbeck CDN M2
The Schwarzbeck CDN M2 device driver is a LISN which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Schwarzbeck CDN M2:
The frequency range of the Schwarzbeck CDN M2 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Schwarzbeck CDN M2.
Be careful changing these settings as RadiMation® is no longer able to verify if the Schwarzbeck CDN M2 is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Schwarzbeck CDN M2
- Google image search: Schwarzbeck CDN M2
