Schwarzbeck FBAB 9177
The Schwarzbeck FBAB 9177 device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Schwarzbeck FBAB 9177:
The frequency range of the Schwarzbeck FBAB 9177 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Schwarzbeck FBAB 9177.
Be careful changing these settings as RadiMation® is no longer able to verify if the Schwarzbeck FBAB 9177 is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Schwarzbeck FBAB 9177
- Google image search: Schwarzbeck FBAB 9177
