Schwarzbeck FBAL 9178
The Schwarzbeck FBAL 9178 device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Schwarzbeck FBAL 9178:
The frequency range of the Schwarzbeck FBAL 9178 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Schwarzbeck FBAL 9178.
Be careful changing these settings as RadiMation® is no longer able to verify if the Schwarzbeck FBAL 9178 is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Schwarzbeck FBAL 9178
- Google image search: Schwarzbeck FBAL 9178
