Schwarzbeck FMZB 1519B
The Schwarzbeck FMZB 1519B device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Schwarzbeck FMZB 1519B:
The frequency range of the Schwarzbeck FMZB 1519B as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Schwarzbeck FMZB 1519B.
Be careful changing these settings as RadiMation® is no longer able to verify if the Schwarzbeck FMZB 1519B is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Schwarzbeck FMZB 1519B
- Google image search: Schwarzbeck FMZB 1519B
