Schwarzbeck HA 9250-48
The Schwarzbeck HA 9250-48 device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Schwarzbeck HA 9250-48:
The frequency range of the Schwarzbeck HA 9250-48 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Schwarzbeck HA 9250-48.
Be careful changing these settings as RadiMation® is no longer able to verify if the Schwarzbeck HA 9250-48 is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Schwarzbeck HA 9250-48
- Google image search: Schwarzbeck HA 9250-48
