Schwarzbeck HLC 27
The Schwarzbeck HLC 27 device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Schwarzbeck HLC 27:
The frequency range of the Schwarzbeck HLC 27 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Schwarzbeck HLC 27.
Be careful changing these settings as RadiMation® is no longer able to verify if the Schwarzbeck HLC 27 is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Schwarzbeck HLC 27
- Google image search: Schwarzbeck HLC 27
