Schwarzbeck MDS 21B
The Schwarzbeck MDS 21B device driver is a Antenna, Absorbing Clamp which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Schwarzbeck MDS 21B:
The frequency range of the Schwarzbeck MDS 21B as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Schwarzbeck MDS 21B.
Be careful changing these settings as RadiMation® is no longer able to verify if the Schwarzbeck MDS 21B is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Schwarzbeck MDS 21B
- Google image search: Schwarzbeck MDS 21B
