Schwarzbeck NNBM 8124-400
The Schwarzbeck NNBM 8124-400 device driver is a LISN which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Schwarzbeck NNBM 8124-400:
The frequency range of the Schwarzbeck NNBM 8124-400 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Schwarzbeck NNBM 8124-400.
Be careful changing these settings as RadiMation® is no longer able to verify if the Schwarzbeck NNBM 8124-400 is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Schwarzbeck NNBM 8124-400
- Google image search: Schwarzbeck NNBM 8124-400
