Schwarzbeck NSLK 8163
The Schwarzbeck NSLK 8163 device driver is a LISN which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Schwarzbeck NSLK 8163:
The frequency range of the Schwarzbeck NSLK 8163 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Schwarzbeck NSLK 8163.
Be careful changing these settings as RadiMation® is no longer able to verify if the Schwarzbeck NSLK 8163 is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
