Schwarzbeck RE 1790
The Schwarzbeck RE 1790 device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Schwarzbeck RE 1790:
The frequency range of the Schwarzbeck RE 1790 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Schwarzbeck RE 1790.
Be careful changing these settings as RadiMation® is no longer able to verify if the Schwarzbeck RE 1790 is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Schwarzbeck RE 1790
- Google image search: Schwarzbeck RE 1790
