Schwarzbeck TEMZ 5233
The Schwarzbeck TEMZ 5233 device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Schwarzbeck TEMZ 5233:
The frequency range of the Schwarzbeck TEMZ 5233 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Schwarzbeck TEMZ 5233.
Be careful changing these settings as RadiMation® is no longer able to verify if the Schwarzbeck TEMZ 5233 is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Schwarzbeck TEMZ 5233
- Google image search: Schwarzbeck TEMZ 5233
