Schwarzbeck UBAA 9115
The Schwarzbeck UBAA 9115 device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Schwarzbeck UBAA 9115:
The frequency range of the Schwarzbeck UBAA 9115 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Schwarzbeck UBAA 9115.
Be careful changing these settings as RadiMation® is no longer able to verify if the Schwarzbeck UBAA 9115 is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Schwarzbeck UBAA 9115
- Google image search: Schwarzbeck UBAA 9115
