Schwarzbeck UBA 9116
The Schwarzbeck UBA 9116 device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Schwarzbeck UBA 9116:
The frequency range of the Schwarzbeck UBA 9116 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Schwarzbeck UBA 9116.
Be careful changing these settings as RadiMation® is no longer able to verify if the Schwarzbeck UBA 9116 is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Schwarzbeck UBA 9116
- Google image search: Schwarzbeck UBA 9116
